How about including a new sampler that mimics regular sampler with a sequencer. Instead of having the childish multiple loop system currently aviailable it would be great to have decent set up that you could monitor and cut up beats with.
geposted Mon 17 Jan 05 @ 2:00 pm
that's why the team made the vdj format loops available on load to the desks. anyway if you use a mixtable you can cut the beats on the loop and work them out
geposted Sun 23 Jan 05 @ 12:26 am
Childish........really... us,no.....maybe a bit!!!
Dude
Load up 12 loops in your sample tray
rec a sequence using the loops that you created or borrowed....hehe
Now you have a file.......correct?
Load that file in a deck and ........voila
You are set to go produce a track
If you need more help just ask
Regards. young man
Andre
Dude
Regards. young man
Andre
geposted Sat 05 Feb 05 @ 9:43 am
