Forum: VirtualDJ Plugins
Topic: SBDJ Random ClipBank Video [PC/MAC] - Page: 6
Could you share the script please??
Huey
Sure, just substitute your clipbank names to correspond with what you have in my example....
video_fx_select "ClipBank hip hop" & video_fx_button 1 & video_fx & video_fx_select "ClipBank hip hop_random" & video_fx
Good Luck,
Joey...
Need some help with this...
The only thing I have missing is the ability to turn the effects off when the same shotcut is triggered the second time after it's active...
Is there a script to do this..?
Where in a script would you place it...?
Thanks...
So I take it the Sonquic Misspelled i know but the effects, are not availale for mac book users???? Please help???? thanks dj jeannette
Wrong thread, but no, Windows only for Sonique.
Hi Scott, is there a script that can turn off a shortcut when pressed a second time?
Thanks,
Joey...
I'm not sure what you mean?
A script like this: video_fx_select "ClipBank hip hop" & video_fx_button 1 & video_fx & video_fx_select "ClipBank hip hop_random" & video_fx
If I press the shortcut keys a 2nd time for the above script it will turn that script off or any part off the script if possible..
Thanks,
Joey....
not sure what you want to do with it Joey, but you can use this simple variable as a basis for an on/off switch...
is the effect on ? turn it off : turn it on
but thinking back to erics post a couple of weeks ago, I couldn't figure out a way to query if an fx is on or off
Just started using Clipbank after using Slideshow (another SBDJ plug) for so long on audio only.
I have everything running, but am a little miffed that I may/will forget to activate the randomiser at the beginning of the night. Would a version that was made for the OTHER folder, remove the requirement of having to activate randomiser every load?
Yes. Yes it would. Good call.
Hi scott,
Can you make a " Folder Randomiser" option or plugin or something that would function that way, a Set It And Forgrt It option....
Thanks,
Joey...
I don't have the spare time required for that at present I'm afraid.
All good, when you have a moment. =)
I was referring to Joey's request - it's a big undertaking to get it right!
Thanks for the reply scott, Hope things are moving in the right direction yeah....
Joey...
**Gets back in box** =)
I am trying to use CLIPBANK RANDOM on a MAC (lion) with VDJ 7.0.5, I can use clipbank plugin with no problems, I have loaded 12 clips, and everything works fine.... I select clip 1 and it plays, but when I click and activate CLIPBANK RANDOM, nothing changes on the video output, the clip bank random plugin says its changing clips every 5 seconds as I configured it, but the video remains the same (clip1), the blue box (focus) remains on clip1 also, if I select another clip manually then the video changes... but clip bank randomizer doesn't seem to be changing the clips, is there anything I am missing?
thanks in advance
It could be you haven't got the randomizer teamed up with your clipbank selection name... as don't have a Mac I could be totally wrong though, have a look at this and see if it helps you....
Thanks Tayla, I only have one clipbank.bundle and one ClipBank_Random.bundle ... I tried creating a second bank clipbank2.bundle and one ClipBank2_Random.bundle and still no effect.... the randomizer appears to be changing the selection but the video is the same unless I click on a different clip...
Maybe the plugin is not finished for the mac ? can anyone confirm that it works under Lion ?
thanks again everyone
89%
