Has anyone done a flange plugin that uses a webcam for input? I was thinking it would be real cool to mount a cheap webcam pointing straight up with a blue USB LED light next to it and use hand positions to control the flange. I think the effect would be tantalizing. Thoughts?
geposted Tue 18 Jan 05 @ 2:36 pm
Very difficult to do it !! And long time to do it !!
geposted Tue 18 Jan 05 @ 3:03 pm
geposted Fri 28 Jan 05 @ 4:51 pm
Hmmm.
There is a freeware program that will translate webcam movement into joystick/mouse commands. Perhaps that would help in the development?
http://www.freelook.org/
I use this to control my view in flight simulator games and it works surprisingly well.
There is also TrackIR, a commercial product, that has their own software and a special webcam that sees IR. It has a very high framerate, plus the IR might make it work a bit better with lights flashing all around in a club. You could use a simple $10 tv remote LED attached to a ring on your hand, for instance and control the flange like that.
http://www.naturalpoint.com/trackir/
Any flanger that uses mouse or joystick as its controller, might be a fairly easy hack into either of these programs. I think I'll tinker with this a bit and see what I can come up with.
geposted Sat 29 Jan 05 @ 9:16 pm
or.. ya could just splash out and but the alesis AirFX ;)
geposted Mon 07 Feb 05 @ 12:48 pm
Yeah, but the hacking is half the fun. =)
geposted Sat 12 Feb 05 @ 8:17 am
hi there speaking about web cam,, somebody please help me to understand the use of this webcam to vdj and also the functions of it pls help i would like to know in details...thank you very much
geposted Sun 06 Mar 05 @ 10:25 am
