Hi Guys!
I've downloaded 5.2 and had it running with the Hercules RMX.
Everytime I disconnect the RMX and then reconnect again it won't recognise it and I get the Windows - Install new Hardware Screen Constantly popping up. Anyone have a solution? I have to unistall the RMX software again and reinstall it to get it to work...
Cheers!
Rob
Cheers!
Rob
geposted Fri 29 Aug 08 @ 8:19 am
Are you using the same USB port all the time, because if you don't it will try and install it's self on all the USB ports.
Use the same one all the time
geposted Fri 29 Aug 08 @ 8:35 am
