Forum: Old versions
Topic: bug with automix
when djing on one deck, i load up the song on the other deck. i have noticed that if i play the song on the other deck but loop it over 8 beats then hit the automix button, the crossfader moves slightly over, but then goes back to the original deck again. it continues to do this even if the first song has played out! it will never move the crossfader over to the other deck unless i turn off the loop. it this the way it was designed, or is it a bug?
any thoughts greatful,
p.s - running an 'old' version 1.06 :-S
geposted Tue 18 Jan 05 @ 11:41 pm
No problem with the last version 2.06 of VDJ
I only have that in my plugin XFade but in this case it's normal
You won't get a lot of help here for such an old version. 1.06 has been outdated for a very long time. I'm sure that most of the users can't even remember what 1.06 was like.
You should completely uninstall your cracked version and at the very least download the latest actual trial version, or at best, if you are enjoying 1.06, you will find it well worth the money to purchase the latest version which is 2.06.
