In the configuration screen of the time-coded vinyl configuration, there you can see the waveform displaying when you put the needle of your turntable on the TCV.
But how should it look in that display area?
And when do you know your sliders for gain and silence are set correctly?
Any help is much appreciated.
Thanks.
Thanks.
geposted Wed 19 Jan 05 @ 9:57 am
thw waveform shout fill about 75% of the box and the silence is for when you stop the vinyl, you raise the silence untill the grey area covers the line as not to react to background noise.
Also only check the pre amp box if your taking your signal from a phono level out turntable otherwise uncheck it
PJay
PJay
geposted Wed 19 Jan 05 @ 11:01 am
Also go here as it tells you everything about setting it up
https://virtualdj.com/products/timecode/
PJay
PJay
geposted Wed 19 Jan 05 @ 11:03 am
hey thanks PJay, I was looking for this configuration, recalled seeing it somewhere, but couldn't trace it back.
I was always on the right track, but wanted some confirmation.
geposted Wed 19 Jan 05 @ 11:59 am
