Forum: Old versions
Topic: TCV, skipping support?
When you work with Time coded vinyl, does VDJ support the positioning of the needle on the record.
Meaning when you put your needle half way the record, is VDJ then positioned in the half of the song in the deck?
geposted Wed 19 Jan 05 @ 10:03 am
yes it does but you have to have above 50% timecode signal quality
oh and its called needle dropping
PJay
Hey, nice one PJay, thanks for giving out the appropriate naming.
I preferred describing the behaviour, in case I would have been using the wrong definition.
Great help.
