cosa mi dite di questo controller questo il link: http://www.reloopdj.com/shop_content.php/coID/12/content/Reloop-Digital-Jockey/language/en/ non somiglia tanto al Total control
Reloop Digital Jockey - Interface Edition
Professional USB/MIDI DJ-controller with USB audio-interface
Exercise: control.
The Digital Jockey by Reloop is dedicated to the future: It makes playing, mixing and manipulating music from a computer\'s hard disc as easy as using DJ CD-players and a mixing console. At the core, the Reloop Digital Jockey is a fully assignable MIDI controller that can send up to 69 MIDI parameters that are accessible via buttons, faders, encoders, push-rotaries, and two oversized high resolution jog wheels. The console scores with full-size DJ-friendly controls, a classic 2-channel layout, high quality faders and backlit control buttons. A huge Trax-encoder allows for the most intuitive browsing in music libraries. The Digital Jockey is easily connected and powered via USB, making it ideal for mobile use.
The Interface Edition features a high grade 4-channel 16 bit/48 kHz USB audio-interface. With that, the Reloop Digital Jockey can be directly connected to the PA, headphones and microphone. And another line source like CD Player or turntable may be integrated into the setup, as well.
In the course of conceptualizing the Digital Jockey, Reloop developed Attack, a professional mixing software that perfectly matches with the controller. The Digital Jockey is not only supplied with Reloop Attack, but also includes the world famous Traktor 3 LE. Both are especially pre-mapped for the Digital Jockey.
Reloop Digital Jockey: The center of exercising control over your music.
Features:
Integrated 4-channel 16 bit/48 kHz USB audio-interface
Stereo RCA input and output, ¼” TRS headphones and microphone connections
Flexible channel routing for integration of CD player or turntable
ASIO drivers for lowest latency and best audio quality
Supplied with 2 professional mixing softwares: Reloop Attack und Native Instruments Traktor 3 LE (both are pre-mapped - no special assignment required)
All controllers in full-size
A total of 69 MIDI-controllers (42 buttons, 5 faders, 9 encoders, 6 push-rotaries, 5 rotaries, 2 jog wheels)
All MIDI-controllers can be edited and freely assigned
USB bus powered: power supply possible via USB
Anti-theft system: Kensington security slot
Mac OSX and Windows XP/Vista compatible
Well-sorted Mixer/CD-Player design for quick and easy handling:
Mixer section
Classic 2-channel layout
1 x PRO longlife crossfader
2 x volume control with PRO longlife linefaders
2 x 3-band equalizer with Push2Kill knobs
2 x gain control knobs
Player section
2 x extra large, high resolution jog wheels for scratching, effect modulation, etc.
2 x PRO longlife pitchfaders
4 x assignable encoders and 4 x buttons for effect and sample control
Total of 42 backlit buttons for all playback operations
Master section
Cue mix, cue volume and master controls
Extra large „Trax“-encoder for fast and easy browsing through the music library (with preview and A/B-load buttons)
Including 2 control overlays adapted for Reloop Attack and Traktor 3 LE, power supply and USB cable.
Exercise: control.
Features:
Mixer section
Player section
Master section
geposted Wed 03 Sep 08 @ 1:11 pm
Sarà buono ma sembra un giocattolo
geposted Wed 03 Sep 08 @ 3:26 pm
però qualcosa di buono cel'ha tipo gli effetti sul deck...
boh come prezzo non è che sia chissa cosa...
mah... mi piacerebbe sentire il parere di qualcuno che ci capisce davvero
geposted Wed 03 Sep 08 @ 3:54 pm
intanto il nome lo hanno azzeccato :-)
geposted Thu 04 Sep 08 @ 4:43 am
aggiungo che hanno lanciato anche un SW Reloopspin abbinato a TC-TCCD e scheda audio
geposted Thu 04 Sep 08 @ 6:49 am
Ma un giretto su Digital Jockey non ve lo afte mai? :)))
http://www.digitaljockey.it/dij/index.php?option=com_content&task=view&id=381&Itemid=59
http://www.digitaljockey.it/dij/index.php?option=com_content&task=view&id=143&Itemid=47
geposted Thu 04 Sep 08 @ 7:08 am
ciao a tutti io ho comprato da qualke mese la reloop digital jockey e la sto usando con traktor 3 LE che è la versione base con soli 5 effetti..volevo integrare virtual dj,di cui posso aggiornare la lista di effetti,skins o altro,con la mia reloop..come posso fare? oppure qualcuno può aiutarmi a trovare un programma con cui poterla usare o spiegarmi come utilizzarla al meglio? grazie mille
geposted Thu 09 Apr 09 @ 1:12 pm
Ciao.
Che software vuoi che ti venga consigliato sul forum ufficiale di virtual dj? :)
puoi fare tutto ciò che vuoi ma ti serve la versione PRO completa acquistabile SOLO da questo sito.
Clicca in alto su "buy" per maggiori dettagli!
geposted Thu 09 Apr 09 @ 3:11 pm
ciao devo avere per forza la versione pro? per traktor 3 le nn posso fare niente? xke per questo programma ho solo 5 effetti e nn posso neanche assegnarli a tutti e 4 i tasti per ogni deck.. mi servirebbe un programma che mi permetta di usare al meglio tutto ciò che è disponibile sul deck e che abbia un buon numero di effetti.. o almeno k li possa aggiungere facilmente.. la versione pro di traktor con 25 effetti mi costava 180 euro in aggiunta alla digital jockeye ora proprio non me li posso permettere..
geposted Fri 10 Apr 09 @ 8:29 am
Eh si....solo la versione PRO completa ti consente una totale gestione degli effetti ma non solo di quelli. Ce ne sono a decine scaricabili sempre da questo sito.
Quote :
Sul forum ufficiale di virtual dj è davvero difficile darti consigli su traktor o su altri software della concorrenza.
Per parlare di altri software ti consiglio il sito amico www.digitaljockey.it
geposted Fri 10 Apr 09 @ 8:37 am
