TOTAL CONTROL MAPPER v1.1
Author: moramax - Team -
Created for VirtualDJ version 5.2
Rev 1.1
- Fixed jog wheels with VirtualDJ 5.1 pro and newer
- Fixed autoexit from browse mode
- Keylock led is implemented
- Unload the song when pause is pressed more then 3 seconds
- Spinback function is improved
Take a look of the mapper manual attach in the zip file (ENGLISH_TOTAL CONTROL MAPPER MANUAL 1_1.pdf)
Compatible starting from Virtual DJ, Numark CUE or Virtual Vinyl PRO 5.2
Download PC & MAC -> http://www.virtualdj.com/addons/tools.html
Many Thanks to Moramax!!!
Rev 1.1
geposted Thu 04 Sep 08 @ 1:36 am
Not a bad plug in, so great thought and expansion on features, just updated with the 2.0, however there are still some things that I just simply dislike for my personal dj style. I can not seem to find any way to remap it myself, so I have deleted the kco files in the My Documents\VirtualDJ\Plugins\ControlDevice folder to remove it. I would really like to see a custom remapping add on for the next version, otherwise I think this is a great plugin, keep up the good work.
geposted Mon 08 Dec 08 @ 12:16 pm
