Hello,
So I have downloaded and installed 5.2.1, I have also downloaded the RMX skin off the site as for some reason it will no longer let me right click in "Remote Control" and let me configure the buttons but I can do that through the skin so no problems there.
How do I manually configure the buttons, I used to do it in the MIDI section of remote control but now whatever I put in there has no effect?
Finally when I loop I press Loop In and then Loop out but it automatically goes to smart loop instead of looping what I want
Any ideas people?
Cheers
Daniel
Any ideas people?
Cheers
Daniel
geposted Sun 07 Sep 08 @ 6:42 am
Try this skin : https://virtualdj.com/addons/4554/Hercules_RMX_variations.html
worked for me.
worked for me.
geposted Tue 09 Sep 08 @ 5:03 pm
Hey,
Yeah thats the skin I downloaded, I can configure the buttons using the skin. But I set buttons 1 and 4 on both sides of the rmx to loop in and loop out respectively but when i actually perform the loop, as soon as I hit loop out it goes to an autoloop and jumps a bit rather than making the loop i have made :S If that makes any sense.....
Cheers
Daniel
Cheers
Daniel
geposted Wed 10 Sep 08 @ 9:53 am
Has anyone had any brainwaves with this I have sorted the other issue, its just the looping button still occurs, which means i have to loop manually using the mouse rather than the buttons on the RMX.
When I use the RMX VDJ skin i leave all the buttons as default but when i hit loop in and loop out it does a kinda autoloop when Loop Out is hit and the song skips rather than looping the sample I want...
Cheers
Cheers
geposted Wed 24 Sep 08 @ 3:37 pm
Don't know if this helps, but please look at this post, it has a link in it to a new plugin.
geposted Wed 24 Sep 08 @ 5:30 pm
Cheers Jimmy B problem solved.....
Now for the new problem lol! I configure the RMX VDJ skin with all the buttons RMX 1-6 and 7-12 for each deck and works like a treat....
When i close the software and reopen again it resets the buttons back to their defaults :( I thought this problem was cured with release of VDJ 5.2.1?!
Cheers
Dan
Cheers
Dan
geposted Thu 25 Sep 08 @ 11:07 am
