Numark - Omni Control
SERIOUS DJ SIMPLICITY
OMNI CONTROL contains everything you need to plug into any club’s house PA and perform. This high-quality, heavyweight, rugged DJ device is not only a hardware controller for performing with the included Native Instruments Traktor 3 LE and MixMeister Fusion Live software; it also houses a professional digital-audio interface to feed your headphones and the sound system.
This complete professional computer-DJ package consists of a hardware controller with built-in audio interface and two software titles: Native Instruments Traktor 3 LE and MixMeister Fusion Live. Stiff, reliable knobs, faders, and buttons are high quality, delivering precision performance. An extremely clean, high-quality sound card feeds pristine audio signal to two stereo outputs and your headphones.
OMNI CONTROL has a heavyweight, sturdy feel thanks to its high-quality controls and rugged metal housing. It'll stay in place even when your fast-scratch technique gets aggressive. Carry less and do more with OMNI CONTROL.
FEATURES:
* Complete professional computer-DJ package
* Hardware controller with built-in audio I/O
* Includes Native Instruments Traktor 3 LE and MixMeister Fusion Live software
* Heavyweight, sturdy feel
* Extremely clean, high-quality sound card
* Stiff, reliable knobs, faders, and buttons
INCLUDES:
* OMNI CONTROL control surface
* Software CD
* USB cable
* Owners manual
Pagina ufficiale http://www.numark.com/omnicontrol
Noto con dispiacere che nella confezione non compare più nessun software made in Atomix, vengono infatti solo citati Traktor 3 LE e MixMeister Fusion anche se sono convinto che questo controller sarà presto nativo su Virtual DJ.
FEATURES:
INCLUDES:
* Software CD
* USB cable
* Owners manual
geposted Mon 08 Sep 08 @ 1:33 am
Pure io credo che diventi nativo in un batter d'occhio, non mi pare che sia molto differente dal Numark Total Control, e non credo a ragione che abbiano stravolto il firmware per una "banale" versione con materiali migliori ma con gli stessi controlli.
geposted Mon 08 Sep 08 @ 4:34 am
son qui che m sforzo a capire che ci fa uno con questo controller e mixmeister, credo che virtualdj lo possa sfruttare a pieno mappando anche le funzioni video o personalizzandolo stile RMX
nel design da notare le intelligenti gobbe agli angoli che proteggono jack e rca e facilitano l'inflightcaseaggio (neologismo appena coniato Spa copyright :-) )
geposted Mon 08 Sep 08 @ 6:11 am
Trovato un video del PLASA 2008
http://www.sonicstate.com/news/shownews.cfm?newsid=7244
geposted Thu 02 Oct 08 @ 7:19 am
ciao
vorrei sapere si ce uno skin di virtual x numark omnia control
e anche si questo legge i formati video
grazie
grazie
geposted Thu 23 Apr 09 @ 12:31 pm
No non c'è e comunque senza licenza non potrai mai scaricarlo.
geposted Thu 23 Apr 09 @ 3:41 pm
C'e la avete qualche info in piu su questa omni control??
Sinceramente mi piace avrebbe anche un buon prezzo ma non ho trovato molte info a riguardo.
vorrei sapere.
1)Funziona con vdj
2) funge solo da controlloer oppure ha una scheda integrata?
3) ho letto che ha due uscite stereo quindi ci potrebbero stare 4 diffusori amplificati o sbaglio?
4) la piu importante:
Vale la pena prenderla oppure a pari prezzi c'e di meglio?
Vi ringrazio per le vostre risposte in anticipo ;))
vorrei sapere.
1)Funziona con vdj
geposted Fri 19 Jun 09 @ 2:36 pm
Questa è dotata di scheda audio a differenza della Stealth Control ,sai anche io ci sto facendo un pensierino....
geposted Fri 19 Jun 09 @ 3:29 pm
Davvero dani.. in effetti e molto bella mi piace molto e poi ha un prezzo abordabile io con i prodotti numark mi son sempre trovato benissimo pero non so se questa funziona bene con vdj vorrei qualche info in piu ragazzi sono tutto orecchi..... ;)
geposted Fri 19 Jun 09 @ 3:41 pm
Ciao a tutti, sono possessore di omni control da un paio di mesi e devo dire che è davvero un ottimo prodotto.
Molto solida, tasti precisissimi e di plastica dura (+ precisi della rmx), aspetto decisamente pro (l'ho scelta provandola a confronto con rmx e xponent e non ho avuto dubbi nel prenderla). Ha la scheda audio integrata con 2 uscite (una la uso per il monitor) ed è al 100 % compatibile con Vdj 6. Finora l'ho provata solo in locali di medio/piccole dimensioni e si è comportata ottimamente, ma non so come si comporta in grandi disco. Cmq il mio consiglio e di guardarla e tastarla dal vivo. La utilizzo in abbinamento con Nano control della Korg, che permette di gestire un elevato numero di effetti e sample supplementari (e ha un costo decisamente ridotto).
In conclusione, per la mia esperienza personale, la ritengo un ottimo prodotto ad un prezzo decisamente conveniente.
geposted Fri 26 Jun 09 @ 1:46 pm
Finalmente......... xfox77 questa e una grandissima notizia..... per me era da tanto che cercavo una info decente ;)
Ero li per li a prendere xponent ma quel discorso del jak difettoso non mi ha convinto tanto.
A me questa omnicontrol piace molto ed a un'ottimo prezzo e poi parliamo pur sempre di numark.
Ora credo di essermi convinto.
Sinceramente essendo un'appassionato di prodotti numark non avevo dubbi ma mi serviva una conferma e me l'hai data.
Ottimo xfox77 ti ringrazio ;)
Speriamo che domani non venga uno a dire che va male :))))
geposted Fri 26 Jun 09 @ 2:56 pm
Ciao Davide, spero davvero che non te ne pentirai...Io l'ho presa al buio perchè come te non ho trovato in rete giudizi di chi l'avesse provata e mi sono fidato delle mie impressioni dal vivo.
Cmq volendo elencare qualche difettuccio (che dipende dall'uso che ne fai) non ci sono ingressi audio (a parte il microfono) e i gain sono un pò vicini, ma nulla di +.
Buon acquisto!
Roberto.
Buon acquisto!
Roberto.
geposted Sat 27 Jun 09 @ 2:22 pm
Come non ha ingressi audio?
Intendi line in?
Perche da quel poco che so dovrebbe avere due uscite stereo se non sbaglio o no.. ?
Ma non ha la scheda audio integrata??
Intendi line in?
geposted Sat 27 Jun 09 @ 4:39 pm
si, scusa se mi sono spiegato male, volevo dire che non ha line in e confermo le 2 uscite stereo (ovviamente la scheda audio c'è)
geposted Sat 27 Jun 09 @ 9:39 pm
Ah.. o capito praticamente non si possono collegare cdj giradischi etc..
In conpenso ha la la scheda audio con due uscite stereo bene a me puo andare anche bene cosi grazie mille..... ;)
PS.vorrei dare un consiglio a tutti quelli che mettono i video su youtube:
Quando mettete i video su youtube e fate vedere le funzionalita di un controller,cdj,mixer o quel che sia.. non fate mai o quasi mai vedere il retro della struttura invece e importantissimo fare vedere le entrate e o le uscite che puo avere un cdj o un controller anche i negozi spesso faticano a mettere la foto del retro.. fatto sta che della omni control non riuscivo a capire cosa avesse dietro oltre all'attacco usb.
Come si dice una mano lava l'altra e tutte e due lavano il viso :))
geposted Sun 28 Jun 09 @ 2:49 am
Ragazzi, rispolvero un attimino questo topic per chiedervi chi di voi ha mai usato il Numark Omni Control con MixMeister? Opinioni?
geposted Sun 01 Jan 12 @ 9:15 pm
pochissimi utenti che io ricordi hanno avuto questa
console, ma a prescindere è fuori luogo parlare
di altri sw sul forum ufficiale di Vdj
geposted Mon 02 Jan 12 @ 2:23 am
Perdonami, non volevo argomentare altri software di mixaggio. Più che altro la mia domanda era prettamente riferita al Control in se più che al software a cui ho fatto riferimento sopra...
geposted Mon 02 Jan 12 @ 4:03 am
