Add-On Midi mapper Pioneer CDJ-400
Description:
These XML files it complete the native control for Virtual DJ 5.2.1, please remember to enable the CDJ-400 Icon and also the MIDI.
Single CDJ-400 - VDJ 5.2.1.xml is for only 1 Pioneer CDJ-400, here the functions:
MEMORY DELETE -> Change Active Deck
REALTIME CUE IN -> Loop (4 beat) on Active Deck
TRACK SEARCH (Backward) -> Skip Beat (-8) on Active Deck
TRACK SEARCH (Forward) -> Skip Beat (+4) on Active Deck
CALL -> Slow Pitch Reset on Active Deck
HOLD -> Sync_no_cbg on Active Deck
Double CDJ-400 - VDJ 5.2.1.xml is for 2 Pioneer CDJ-400, here the functions:
MEMORY DELETE -> Active Deck
CUE -> Active Deck and Start the music
HOLD -> Sync_no_cbg
Good Work!!!
PS. Many thanks to Cioce for support and translation!
Download -> http://www.virtualdj.com/addons/tools.html
Description:
HOLD -> Sync_no_cbg
Good Work!!!
geposted Fri 12 Sep 08 @ 3:06 am
Is the native support able to be customised?
geposted Tue 02 Dec 08 @ 5:37 am
