Working on my plugin, cannot find a way to move the knobs using MIDI control or even the knob on VDJ. I believe I was able to move some knobs depending on the PRESET name of the control on the VST. It seemed as if VDJ would assign the first control to the PARAM 1 knob on VDJ. But on this vst I am creating, the knob does not rotate. Anything I'm missing?
geposted Sat 13 Sep 08 @ 12:29 am
First of all dre99gsx welcome among PROFESSIONAL USERS; you made a good decision and I'm glad you did it!!
In my case my MIDI controller works good:
1) the first knob changes the FEEDBACK;
2) the second knob changes the MIX;
3) the third knob changes the FADE OUT;
4) the fourth knob changes the DELAY;
5) the fifth knob changes the HIGH;
To set the Knobs on your MIDI controller go in MIDI SHORTCUT->EFFECTS->EFFECT_SLIDER_1/2/3/4/5; this way allows yourself to set 5 knobs for controlling 5 faders of any effect you wish.
geposted Sat 13 Sep 08 @ 6:51 am
I add:
for now it's only possible to link 5 faders with 5 knobs
geposted Sat 13 Sep 08 @ 7:52 am
