How do you submit a xml mapper update file?
I have made some modifications in the denon DN-S1200 xml file. How do i submit that file and the explanations?
geposted Sat 13 Sep 08 @ 1:26 pm
Mapper is now available here http://www.virtualdj.com/addons/4820/Denon_DN-S1200_midi_mapper.html
Are you sure the XML is not PC compatible?
Do you think the midi channels are different?
geposted Sun 14 Sep 08 @ 4:22 am
