Forum: VirtualDJ Skins
Topic: Multi function 3
Hi,
Does anyone use Multi function 3 skin?
I can't get the mix button at the top to work, I have used multi function 2 for quite a while and the mix button works no problem, I just wondered if there was an enable or disable on this skin and I am missing it somewhere.
Cheers
billy24
geposted Sun 14 Sep 08 @ 1:33 pm
Click AUTO to enable automix
Click MIX to force automix to skip (AUTOMIX must be enabled)
SQ;p
