Forum: VirtualDJ Plugins
Topic: RMX 6+6 buttons config v1.0 by DJCel for Virtual DJ 5.2 - Page: 1
A mapper for the rmx would be great , heared about some one is on it yet.
Thanks .
J
geposted Tue 16 Sep 08 @ 1:56 pm
I think alot of people are waiting for a mapper
i the mac version coming also ?!
For give me for being abit thick Cioce, but say if I want to change 4 button action, then I have to have 4 plugins.
The decriptive is not all that clear, thanks.
Thats what it looks like to me from the description :)
RMX config v1.0 by DJCel
Compatibie VirtualDJ 5.2.1
Attention: This TOOL is an audio effect and it require a skin with dedicated slot multibuttons like for example:
Vinyl Scratch variations (Scratch5:Basic_Gray(1280x800) v2) http://it.virtualdj.com/addons/4369/Vinyl_Scratch_variations.html
or latest Hercules RMX http://it.virtualdj.com/addons/4554/Hercules_RMX_variations.html
Follow this procedure to map the buttons:
1) Download and install RMX1.exe
2) enter into the folder C:\Documents and Settings\Digital\Documenti\VirtualDJ\Plugins\SoundEffect
copy for 12 times the dll and rename like:
RMX1.DLL
RMX2.DLL
RMX3.DLL
RMX12.DLL
3) open Virtualdj and enter in the effects zone, click on RMX1 and select the action (shortcut):
4) load the effect into the slot (right click and select)
Fx1= button 1 RMX
Fx2= button 2 RMX
Fx3= button 3 RMX
Fx4= button 4 RMX
Fx5= button 5 RMX
Fx6= button 6 RMX
5) Follow the same procedure for the other deck.
Download -> https://virtualdj.com/addons/4830/RMX_config_.html
I don't know.
@ jimmy b
Waiting for a beer :))))
Thanks to DJCel for the tool and to Moramax for the print screen ;)
cioce wrote :
@ jimmy b
It's in the post mate ;)
Thanks Cioce, I undersatnd now mate.
I will try it out after the weekend.
Yes the code is MAC compatible that's why I used this solution.
I have started a new version of this plugin which is easier to use and avoids to copy the dll.
As soon as i can do it, I will finish and compile it for PC & MAC.
Hey There i didn't quiet figured it out how to put the effects in to my rmx ??
cause i don't quiet understand the discription ....
I Followed all of the steps and got stuck on the 3rd one, because i can't open the slots
to put in any of the FX ....
Can someone help me out?
Thnx
jje vna pregvnta se pveden descargar los efectos?
Please don't SPAM, otherwise your account will be LOCKED!
hello
so thanks a lot for this plugin. My buttons work great with the new Version.
A big thanks to Dj Cel who made the Plugin and to Cioce for the nice explantation.
Ps: Armin and i will make a german explantation for our forum users :-)
Hey, could you make your plugin that it works like the "RMX Button Configurator" from moramax??
I dont want to use an other skin to make this work. Ill just use the "Internal Mixer" Skin. The RMX Button Configurator doesnt work with newer Versions than 5.1 ;-((
cu
pOpY
tell me a license code, please. i can't download plugins from this site
A licence is here https://virtualdj.com/buy/ ;)
@ pOpYDJ
Sorry but fot the moment this is the only way to MAP the 6+6 buttons with VDJ 5.2.
thank you, cioce!
Hi i'm able to map the buttons but when i close VDJ the mappings are lost. Is this the case for everyone or am i doing something wrong??
Cheers
Thats not good news ;-(
The RMX Hardware works very well, but it seems nobody would write a REALLY mapper ;-(
cu
pOpY
For what I know the best "mapper" teamer (Moramax) is at work to release a mapper ;)
thank you cioce!;)
yes, i'm working on an optimized mapper for the Hercules RMX.
21%
