A mapper for the rmx would be great , heared about some one is on it yet.
Thanks .
J
Thanks .
J
geposted Tue 16 Sep 08 @ 1:56 pm
I think alot of people are waiting for a mapper
geposted Tue 16 Sep 08 @ 2:16 pm
Easy, just download http://www.virtualdj.com/addons/4830/RMX_config_.html & map ;)
geposted Wed 17 Sep 08 @ 3:02 am
i the mac version coming also ?!
geposted Wed 17 Sep 08 @ 6:20 pm
For give me for being abit thick Cioce, but say if I want to change 4 button action, then I have to have 4 plugins.
The decriptive is not all that clear, thanks.
geposted Wed 17 Sep 08 @ 6:27 pm
Thats what it looks like to me from the description :)
geposted Fri 19 Sep 08 @ 7:41 am
RMX config v1.0 by DJCel
Compatibie VirtualDJ 5.2.1
Attention: This TOOL is an audio effect and it require a skin with dedicated slot multibuttons like for example:
Vinyl Scratch variations (Scratch5:Basic_Gray(1280x800) v2) http://it.virtualdj.com/addons/4369/Vinyl_Scratch_variations.html
or latest Hercules RMX http://it.virtualdj.com/addons/4554/Hercules_RMX_variations.html
Follow this procedure to map the buttons:
1) Download and install RMX1.exe
2) enter into the folder C:\Documents and Settings\Digital\Documenti\VirtualDJ\Plugins\SoundEffect
copy for 12 times the dll and rename like:
RMX1.DLL
RMX2.DLL
RMX3.DLL
RMX12.DLL
3) open Virtualdj and enter in the effects zone, click on RMX1 and select the action (shortcut):
4) load the effect into the slot (right click and select)
Fx1= button 1 RMX
Fx2= button 2 RMX
Fx3= button 3 RMX
Fx4= button 4 RMX
Fx5= button 5 RMX
Fx6= button 6 RMX
5) Follow the same procedure for the other deck.
Download -> http://www.virtualdj.com/addons/4830/RMX_config_.html
I don't know.
@ jimmy b
Waiting for a beer :))))
Thanks to DJCel for the tool and to Moramax for the print screen ;)
RMX1.DLL
RMX2.DLL
RMX3.DLL
RMX12.DLL
Fx1= button 1 RMX
Fx2= button 2 RMX
Fx3= button 3 RMX
Fx4= button 4 RMX
Fx5= button 5 RMX
Fx6= button 6 RMX
I don't know.
@ jimmy b
geposted Fri 19 Sep 08 @ 7:52 am
cioce wrote :
@ jimmy b
It's in the post mate ;)
Thanks Cioce, I undersatnd now mate.
I will try it out after the weekend.
geposted Fri 19 Sep 08 @ 8:53 am
Yes the code is MAC compatible that's why I used this solution.
I have started a new version of this plugin which is easier to use and avoids to copy the dll.
As soon as i can do it, I will finish and compile it for PC & MAC.
geposted Fri 19 Sep 08 @ 7:13 pm
Hey There i didn't quiet figured it out how to put the effects in to my rmx ??
cause i don't quiet understand the discription ....
I Followed all of the steps and got stuck on the 3rd one, because i can't open the slots
to put in any of the FX ....
Can someone help me out?
Thnx
Thnx
geposted Wed 24 Sep 08 @ 3:34 pm
jje vna pregvnta se pveden descargar los efectos?
Please don't SPAM, otherwise your account will be LOCKED!
geposted Sun 28 Sep 08 @ 12:04 am
hello
so thanks a lot for this plugin. My buttons work great with the new Version.
A big thanks to Dj Cel who made the Plugin and to Cioce for the nice explantation.
Ps: Armin and i will make a german explantation for our forum users :-)
geposted Tue 30 Sep 08 @ 7:37 am
Hey, could you make your plugin that it works like the "RMX Button Configurator" from moramax??
I dont want to use an other skin to make this work. Ill just use the "Internal Mixer" Skin. The RMX Button Configurator doesnt work with newer Versions than 5.1 ;-((
cu
pOpY
cu
pOpY
geposted Fri 31 Oct 08 @ 1:45 pm
tell me a license code, please. i can't download plugins from this site
geposted Tue 04 Nov 08 @ 3:03 am
A licence is here http://www.virtualdj.com/buy/index.html ;)
@ pOpYDJ
Sorry but fot the moment this is the only way to MAP the 6+6 buttons with VDJ 5.2.
@ pOpYDJ
geposted Tue 04 Nov 08 @ 3:45 am
thank you, cioce!
geposted Wed 05 Nov 08 @ 1:41 am
Hi i'm able to map the buttons but when i close VDJ the mappings are lost. Is this the case for everyone or am i doing something wrong??
Cheers
Cheers
geposted Thu 06 Nov 08 @ 3:18 pm
Thats not good news ;-(
The RMX Hardware works very well, but it seems nobody would write a REALLY mapper ;-(
cu
pOpY
cu
pOpY
geposted Fri 07 Nov 08 @ 1:04 pm
For what I know the best "mapper" teamer (Moramax) is at work to release a mapper ;)
geposted Fri 14 Nov 08 @ 1:31 am
thank you cioce!;)
yes, i'm working on an optimized mapper for the Hercules RMX.
geposted Fri 14 Nov 08 @ 9:04 am
