I'm on the sound and lighting guys PC at my gig writing this.
I can't get the Random Clipbank plugin to run right, it will do 2 or 3 clips then freeze. Been messing with it for about 1/2 hour now, but no luck. Got everything update for these plugins to run BTW.
Starting to get busy now, so I'm going to sack it off tonight and test in again in the morning at home, Poo.
geposted Fri 19 Sep 08 @ 5:09 pm
No idea what's causing that, I've been using this plugin for as long as I can remember!
Does it still freeze if you allow duplicate video clips in the config?
geposted Fri 19 Sep 08 @ 6:41 pm
jim if you are still working and if you can do a quick switch to cd's make your your sound card to 4:1, still with the rest of the rmx settings
geposted Fri 19 Sep 08 @ 7:23 pm
Cheers for that paul, but I'm home now mate. I couldn't do that anyway mate, I was on my vinyls tonight, maybe that's why, something to do with timecodes?
All the other times I've used this plugin is with my RMX.
geposted Fri 19 Sep 08 @ 7:48 pm
scott, it has to do with the rmx, as long as it's in the 4:1 settings it is ok, has nothing to do with the plug in...
geposted Fri 19 Sep 08 @ 8:20 pm
Really?! Thats a bit strange isn't it?!
geposted Sat 20 Sep 08 @ 6:36 am
had the problem when i was using the beta version (actually still using it) found the problem was in the sound card settings so as long as the user is using the 4:1 settings in sound card, random clip bank will work without giving out a stutter effect. hope that helps.
geposted Sat 20 Sep 08 @ 8:01 am
Been playing around with it this afternoon at home, it certainly does not like timecodes, well not mine anyway, lol
With my RMX it seems fine.
Strange is that.
Strange is that.
geposted Sat 20 Sep 08 @ 9:07 am
Very odd, fired up my timecodes - admittedly not with the RMX, but with my ASIO Ecler Evo 5, and had no problem.
I can't see how the choice of soundcard would affect my plugin... most odd.
geposted Sat 20 Sep 08 @ 11:20 am
I use my Maya for timecode's Scott.
geposted Sat 20 Sep 08 @ 11:39 am
I have a Maya kicking around, will have a play tomorrow...
geposted Sat 20 Sep 08 @ 12:55 pm
