Forum: Old versions
Topic: Problem with saving and loading loops
Hi everybody,
I have a problem with saving and loading loops. I am using a skin so I am not sure if this feature might work better with the normal view. Whenever I create a loop and set it to run through any one of the loops in the sample menu I can save them but then when I try to load a loop I saved it says the sample is empty. Any ideas about this? I want to save loops to use at a later time any ideas?
thanks
geposted Mon 24 Jan 05 @ 7:58 am
Hi.
It is possible to save your loops to be used at a later time.
However, I believe you must be a register user, which
mean you have to buy the full version of vdj.
You'll be able to download cool plugs-in, special effects.
and different skins as well. But most important, Technical Support.
Hope to see you as a Member soon.
