Forum: Old versions
Topic: help on virtual dj v2.05 trial version??
Well i just downloaded virtual dj v2.05 trial version from this website and im having a problem i downloaded i install it and i click on the shortcut on the virtual dj icon and an error comes up and says "database is corrupted and when i click ok another error comes up and says " invalid skin file(error line%i in the xml). can some1 help me out and tell me how im supposed to install it right because i know the file is not corrupted because i downloaded it from this website. by the way this virtual dj v2.05. any suggestions, i reinstall it like 20 times and i keep getting this error alot.
geposted Tue 25 Jan 05 @ 5:39 am
please uninstall, and DELETE the Virtual DJ folder.
The xml error is because of a bad skin, and the database error might only be because you restart the program to fast (virtualdj need to rebuild the database each time it quits)
so u want me uninstall virtual dj then delete the virtual dj folder and then try to install it and it should work right. after i install it do i click on the virtual dj shortcut on the desktop right away. let me try
did it help? :) hope so
