Right, the only problem i've got is the pitch on the dac 2 controller.
When plugged into the usb port the pitch only goes in the plus direction not minus.
When i put the dac 2 mapper dll file into the correct folder the pitch will minus but not plus.
Any ideas????
Thanks
Craig
Any ideas????
Thanks
Craig
geposted Fri 03 Oct 08 @ 1:51 pm
If you use my DAC-2 mapper and the latest version of VDJ. Then you should download the latest version of the mapper:
https://virtualdj.com/addons/5023/DAC-2_Mapper.html
geposted Sat 04 Oct 08 @ 2:27 am
Thanks Pern, i will try it.
Tried the dac-2 on Thursday night and that was using old mappers, i see you created a new mapper update available on the downloads section on the same day. lol
geposted Sat 04 Oct 08 @ 12:17 pm
I found a small "bug" in the mapper... It doesn't show the loop length on the screen of the dac.
No huge problem but sometimes it's annoying. :) Works great at everything else. Still my fav dac2 mapper :)
geposted Sun 05 Oct 08 @ 6:25 am
Strange , that part of the code isn't changed. But i will check it.
geposted Mon 06 Oct 08 @ 12:17 am
Oh and i've got another suggestion. When in a loop, is it possible to make the button with the arrow to the right to also make the loop shorter, but on the other side? I'll try to illustrate this.
[ - - - - ] 4 beat loop
- When pressing the left arrow
[ - - ] - - first two remain
- Pressing it again
[ - ] - - - in half again, of course you know this already.
- Right arrow while in a loop does this now:
[ - - - - ] --> [ - - - - - - - -] Turns a 4-loop in an 8-loop
- I'd like it if it did this:
- And pressed again
If you listen to Laidback Luke sometimes: he uses that kind of loops quite often and it sounds very pro :) Might it be possible to integrate this in your mapper? Or make an option for it?
- Pressing it again
- And pressed again
geposted Wed 08 Oct 08 @ 4:30 am
So when pressing Right it should move forward, set a new loop start and devide the loop length by 2 ?
geposted Thu 09 Oct 08 @ 1:13 am
It should make the same loop shorter, but using the front half instead of the rear half. :)
geposted Thu 09 Oct 08 @ 3:21 am
