Forum: VirtualDJ Skins
Topic: VDJ5: Change key to camelot
Anyone,
On VDJ5, I want the display to read the camelot instead of the key.
Looking at the XML, do I change only the "format="%Pkey"" to format="%Pcamelot" for both decks?
Is it that simple? What steps are missing? First time messing with it.
I don't mess with the graphics?
Thanks for your help.
FLeX
geposted Sat 04 Oct 08 @ 10:47 am
Change %Pkey to %camelot to see the camelot code instead of key.
I don't know if %Pcamelot will work.
%pcamelot works....
I was uneasy messing with it. You know the saying if it isn't broken leave it...until now.
I tried the Pcamelot and it did work.
Thank you glamourpuss.
cant seem to find key in the multifunctions 2.1 skin. anyone help me out? would rather it was in camelot then normal. thanks
