Forum: Old versions
Topic: Question on Virtual DJ 2.6
Hi!
Is the Hercules Dj console compatible with virtual DJ 2.6?
Thx!
geposted Wed 26 Jan 05 @ 7:56 pm
yes it is (2.06) :)
the console have even better support in 2.06 ...
Like the possibility for scratch (basic) with jogwheels...
If you have an HDJC and you are thinking of upgrading, DO IT. The full version does alot more than just allow you to scratch. It has better options for routing audio (using an external mixer with HDJC), support for other controllers, plugins, skins, effects and the list goes on. Plus you get this cool thing next to your username when you post in the forums.
