Forum: VirtualDJ Skins
Topic: 3 decks
I'm looking for a skin that has 3 decks in it.
Don't feel like working with two network connected instances of VDJ, as it doesn't give the flexibility of having the three next to eacht other.
Any help is welcome.
geposted Wed 08 Oct 08 @ 5:22 am
You're out of luck then. The software only presently supports more then 2 real decks by use of a multi-instance setup.
grasias
Damit,, that was a good idea 3 decks too bad it doesen't sopurt it
Hmm... I thought there were skins that supported 4 decks somehow. Not sure how to make that work myself, I've never tried it.
As I said, multi-instance skins do, but with quite a few restrictions :)
