Forum: Old versions
Topic: removing virtual dj trial
ok this what happen i didn't download virtual dj v2.05 trial so i quit it and i tried deleting it from my desktop and it says " that some other program is using it" but i don't even have it install any suggestion on deleting it from my desktop. thanks
geposted Thu 27 Jan 05 @ 10:28 am
1 add-remove
2-program files ...check if there is any left here
3 run (regedit) and delete all that is vdj except xml database
4 do a serch to see if there is any thing left
5 if you loaded a cracked version you will have to reformat eventually
good luck....hope to see you as a pro user soon!!!
Andre
