Forum: Italian Forum
Topic: Controller DJ-Tech i-Mix USB DJ-Konsole MIDI 2
Ecco dei bei controller che non vanno sottovalutati
i-Mix
NEW
Professional USB DJ Console
  • 2-deck controller
  • Mix 2 files in 1 controller
  • Totally portable
  • Smaller than a laptop
  • USB-bus powered: no extra power needed
  • 2 Professional Jog-wheels to mix audio files
  • Pitch , Search and Scratch
  • 3 faders
  • 1 Crossfader (mix 2 decks)
  • 2 volume faders (1 per deck)
  • 6 equalization filters with 6 Kills
  • Bass, medium, treble knobs
  • 3 level equalization per deck
  • Package content :
  • 1 x DJ mix controller USB powered
  • 1 x PC DJing Software : Mix Vibes 3DEX Le
  • 1 x USB Cable
  • Minimum System Requirements (PC):
  • WindowsXP (SP2) / Windows Vista
  • Pentium III or AMD Athlon 1GHz
  • 512MB RAM
Dovrebbe costare € 145,90
PRODUCT DESCRIPTION
DJ-Tech’s i-Mix is a DJ software controller for DJs who yearn for the control they left behind when they switched from a traditional mixer to the multi–processing power of laptop DJing.
i-Mix is a fully class–compliant USB MIDI device and is the ultimate tool for any performing computer DJ seeking total control of their software.
i-Mix's 48 buttons, 10 knobs and 5 faders send MIDI data from the controller to your DJ software of choice, making the inconvenience of mouse or glide–pad software control a thing of the past. No assignment of software parameters for the i-Mix is necessary – simply connect the controller to a computer with a USB cable, enable it in your DJ software’s configuration screen, and watch the virtual controls respond to i-Mix’s actions.
The i-Mix comes packaged with ******** software, with pre–mapped controls and overlay “skins” for both applications.
Non solo c'è pure un altra versione
i-Mix Reload
NEW
Portable USB DJ Mixer & Scratch Controller
2-deck controller
  • Totally
  • 4 kg ONLY for 36(W )x 25.5(D) cm
  • 2 Professional Touch sensitive Jog-wheels to mix audio files
  • 3 Faders + 4 FX POT with 4 Knobs
  • 3 level equalization per deck and PFL
  • Headphones Cue Mix and Volume
  • Package content :
  • 2 x PC DJing Software : Deckadance Le & Traktor 3 LE
  • 1 x USB Cable
  • Minium System requirement
  • Processor:
  • PC: Intel Pentium III 1 GHz or Athlon XP 1.4 GHz
  • Mac: G4 1.5 GHz or Intel® Core™ Duo family
  • OS: PC: Windows XP(SP2)/Vista / Mac: OSX v10.4 (Universal Binary)
  • Memory: 512MB Ram
  • Sound card:
  • PC: DirectSound or ASIO compatible soundcard
  • Mac: Sound card with CoreAudio drivers
  • Hard Disk Space: 200MB free space
PRODUCT DESCRIPTION
The DJ-Tech i-Mix Reload has been designed to enable mobile DJs as well as club & studio DJs to mix digital music. This "nomadic" device simply connects to the USB port of a PC or Mac® laptop.
Broad enough in size to allow DJs to mix with unrivalled ease and precision, it is also compact enough to follow users to any event - its measurements (360W x 255D x 64,5H mm) for only 1,4 kg, are equivalent to those of a laptop computer.
For live mixing and seamless integration with the DJ’s professional environment, the DJ Console i-Mix Reload features a solid ABS casing and 2 Metal Jog Wheels with Patented Touch sensitive which are adjustable: Perfect stability and Guaranteed Excellent Scratch Performance and Real Vinyl feeling.
The i-Mix Reload comes with Traktor 3LE and Deckadance Le which are 2 references in the DJing world for PC& Mac.The software includes features and settings specific to the i-Mix Reload, and combines the power of the VirtualDJ mixing engine with the ergonomics of our platform.
i-Mix Reload is a MIDI controller and therefore compatible with other MIDI-controlled software applications and it is fully able to control any of the best soundcard of the market, specially the ones that you already got into your skin.
Compatible with standard DJing digital music libraries, i-Mix Reload enables DJs to mix the music files stored on their PC or Mac® in the following formats: MP3, AIFF, WAV, WMA, OGG & CD Audio, as well as the iTunes® library.This is the Perfect DJ TOOL controlable by anyone : Let’s Party !!!!
Fonte su Virtual dj
http://www.virtualdj.com/forums/97594/German_Forum/Billg_Controller__DJ-Tech_i-Mix_USB_DJ-Konsole_MIDI_2.html
Fonte sul web
http://www.djtechpro.com/product.asp?sub_id=99&category_id=45&sub_name=Computer%20DJ
Alla Prossima
geposted Thu 09 Oct 08 @ 10:19 am
ricordo di averli visti e toccati al MusicMesse di Francoforte,
dove l'amico CyberMix si e documentato a dovere presso gli espositori
e ne ha fatto un apiccola recensione su www.DigitalJockey.it
Ricordo che questi controller son MIDI compatibili al 100%
saranno disponibili al publico europeo ad un prezzo molto concorrenziale (a partire da circa 200 euro)
e ci sono confezioni con incluso anche un software per mixare (non VirtualDJ).
Augh !
geposted Thu 09 Oct 08 @ 10:24 am
DJ CONTROLLER USB DJ TECH I-MIX
geposted Mon 02 Sep 19 @ 4:24 pm
che volevi sapere?
geposted Sat 07 Sep 19 @ 2:02 am
