which file do i need to copy to my new laptop so that the music lists / cue points and playlists come up the same as on my old laptop thanks
shaun
shaun
geposted Thu 09 Oct 08 @ 2:03 pm
The xml file from the hard drive with you music should do it.
geposted Thu 09 Oct 08 @ 3:08 pm
You need to copy the mp3database.xml file.
Hope this helps
geposted Thu 09 Oct 08 @ 8:26 pm
It only works when you have the same root folder and other underneath folders !!!
geposted Fri 10 Oct 08 @ 4:03 am
so what do you do if the new computer has the music on a diffrent drive letter?
geposted Tue 21 Oct 08 @ 12:28 am
just put the file on the hard drive it worked for me
geposted Tue 21 Oct 08 @ 1:37 am
What Version are you using???
geposted Tue 21 Oct 08 @ 4:22 am
