Hi,
Not sure if this has been posted before and if it is even already possible but for people with only two sets of outputs and using an external mixer it might be nice to select one of the deck outputs to send samples to (perhaps the active deck) during a mix rather than needing an additional soundcard. I assume sending them to both decks simulataneously would be a bit rubbish as the volumnes would be combined if the fader was in the middle. But to select one of the deck outputs during playback would be cool.
geposted Thu 27 Jan 05 @ 4:27 pm
But the problem is that sometimes you play with the deck volume (even the default) when playing some samples.
I prefer to assign the samples to a third output.
geposted Thu 27 Jan 05 @ 11:04 pm
Amen ...we need a third output , with asio drivers too please
geposted Fri 28 Jan 05 @ 12:01 am
you can assing to a third outout, with a third soundcard...
geposted Fri 28 Jan 05 @ 4:36 pm
... but not in Low latency Timecode mode...
geposted Mon 31 Jan 05 @ 2:57 pm
