Forum: Old versions
Topic: Cross fading problem since upgrading to 2.06
Hi
since i've upgraded to 2.06 when the the crossfader (VDJ crossfader) is all the way over the to the left or to the right i can still hear the opposite decks music playing. It's as if the crossfader just isnt in its maximum left or right position
Any ideas, suggestions?
Thanks!
geposted Thu 27 Jan 05 @ 7:27 pm
What are your settings......full,cut..
Did you try another skin?
Andre
I've tried all the various crossfader settings and the problem occurs in all the skins i have, including the standard skin.
It maybe worth noting that i use the Hercules Console, but the problem still occurs if i don't connect the console.
Your soundcard settings are most likely wrong.
What mode and setup have you chosen in Virtual DJ ?
