Has anyone else noticed that the Eject and Playlist buttons on the EKS XP10 are not mappable in VDJ. Not a big deal really but that's 2 more buttons I could be doing something with. Has anyone figured out how to map them to do something,... anything?
I notice the Atomix XP10 have those buttons as well. What do they do, if anything?
geposted Thu 27 Jan 05 @ 10:06 pm
it may be shift key?
geposted Thu 27 Jan 05 @ 10:14 pm
Or to mute the deck...(new sv skin)
Andre
Andre
geposted Thu 27 Jan 05 @ 11:20 pm
on the VDJ unit, eject is labeled shift1 and playlist is labled shift2.
so in your mapping of, say, the play button, in the shift1 tab you can map the action that you want to happen when you press shift1 + play (ie eject+play for you). very handy!
geposted Fri 28 Jan 05 @ 8:41 am
