Forum: Old versions
Topic: error on virtual dj v2.05 trial
ok i know i had this problem before but for some reason it keeps happening. can any 1 that had this problem help me out from step 2 step on to install it correctly everytime i install the trial and i click on the virtual dj icon on the desktop it keeps saying " file corrupted" and after that it says "invalid skin error" so any suggestion will help. i mean i know im install it right. i mean after i install it i tried to restart the computer to see if that will make a difference but i still get the same error.
geposted Fri 28 Jan 05 @ 9:16 am
Did you install a crack version in the past?
yeah y u think thats the problem and if it is tell how to remove it or fix it
