Forum: Old versions
Topic: new hercules drivers
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=143&cid=1
anyone try them?
Hercules DJ Console 1.HDJ.2005 package
2005-01-21
Installation:
1- Uninstall the previous driver version: to do so, click Start/Settings/Control Panel. Select the Add/Remove Programs icon, then uninstall Hercules DJConsole. Alternatively, you can simply launch this package: it will uninstall the previous drivers.
2- Reboot your PC.
3- Launch this package to install the new drivers.
4- At the end of the installation, you may be prompted to update your firmware version (Version 35) if you had not already update it. Please strictly follow the on-screen instructions for this very important procedure.
5- You are now ready to use your DJ Console.
Contents:
Bulk Driver Version 2.2.0.0
ASIO Driver Version 2.2.0.0
Firmware Version 35
Control Panel Version 1.2.4.0
Changes:
- Fixed an installation issue that in some cases causes the Control Panel not to see the DJ Console after upgrading from package 4.HDJ.2004.
 [Windows 2000/XP ] 3.5 MB
 [Mirror site] 3.5 MB
geposted Fri 28 Jan 05 @ 2:20 pm
