Hi djcel, this one's for you:
I find your screen resizer plugin very handy, especially given virtualDJs inability to control the aspect ratio of videos properly and such.
I do have a few suggestions/requests for you to consider if you were to work on it and further enhance your plugin, and I appreciate your consideration of them.
1. Put a reset button on each axis so that you can easily go back to zero.
2. Allow for a few preset selections (buttons) for common aspect ratios, and if possible, allow custom presets to be saved as well.
i.e. 4:3 16:9 16:10 (of course the calculation of these will be based on your current screen aspect, so it's rather relative, perhaps you need to have the user dial in their current aspect first with a radio button?)
3. Remember the setting used on a particular song so that it will automatically adjust when loading that song again. (of course when you load a song in the next deck, this will break, because it resizes the master output anyways :P)
Would anyone else out there find this useful?
geposted Sun 19 Oct 08 @ 11:56 am
Would love to have this for the MAC... Please consider
geposted Sat 25 Oct 08 @ 7:42 pm
