VirtualDJ font is too small on the record case and skins
VirtualDJ record case does not support ID3 tags. This is a big deal since he has all of his collection organized with genre, album, year, etc.
VirtualDJ Supports more controller options than traktor
Traktor Can not use effects like VirtualDJ
Traktor has NO Skins at all, VirtualDJ has many skins
Traktor scratching is limited and does not sound as realistic as VirtualDJ
Traktor is 100% stable, VirtualDJ crashed on us once
Traktor has better master tempo quality than VirtualDJ and has three levels (low, medium, high)
Traktor supports explorer based record case as well as ability to LOAD and save playlists
Traktor has a record case player to preview the track before loading to a deck
I still like VirtualDJ better than traktor but both of them have their positive and negative points.
WirelessDJ
geposted Sun 30 Jan 05 @ 6:36 am
geposted Sun 30 Jan 05 @ 6:46 am
VDJ has that ability. The size of the text doesn't help but it does have that ability nevertheless.
The things you mentioned VDJ not having are all true shortcomings. They can be fixed and Im sure the DEV team is hard at work as we speak.
Killabee44
geposted Sun 30 Jan 05 @ 6:48 am
"Traktor is 100% stable, VirtualDJ crashed on us once"
%$#+%_$+%!!!!
VERY bad for a DJ soft.
geposted Sun 30 Jan 05 @ 1:41 pm
geposted Sun 30 Jan 05 @ 3:11 pm
VirtualDJ fonts are completely customizable and easy to modify. From what I know, Traktor has no provision for the user to easily modify fonts. The wide array of available VDJ Skins leaves Traktor way behind in this category. Heck, as you know VDJ even has a Traktor skin if you just can't get away from that Traktor look.
The way a user organizes his collection is his personal preference. Although ID3 tags may be more convenient for some, those that use folders, file naming and playlist techniques to organize their library are just as effective.
VirtualDJ Supports more controller options than Traktor
This says a lot more for vDJ development than it does for tracktor's developers, doesn't it ?
Again, an indication of how much Traktor developers listen to their users. I was a Traktor user at one time and this was a huge frustration point for me. Development completely ignore's user input.
[:o)
I don't have much of an opinion here. I haven't scratched since I put down my 1200s.
Shame on you Wireless. If you are going to bring your rig to a club to compare against the competitor, you should ensure that your system is a proven stable install of vDJ. There are many of us using vDJ for almost 2 years without crashing.....
ok
I don't know... what would you call vDJ's Explorer window ? Last time I checked I was able to load and save playlists in vDJ just fine. Maybe I misunderstand the point.
You should get to know vDJ a little better.... this functionality has been there for a long time (right click) ... also try using vDJ Playlist as a record case.
[:o)
geposted Sun 30 Jan 05 @ 5:09 pm
It has some increadible programmers, and the power to develope cutting-edge stuff. BUT, they're not a DJ-dedicated company, and that's what makes the big difference.
Plus, VDJ's developers seems to be kick ass too.
How come we never get to chat with 'em? :)
Alex
geposted Sun 30 Jan 05 @ 9:13 pm
