Installing a plugin is easy, I just cant seem to find how to uninstall a plugin. Theres a few video effects I have installed that I dont need or work the way I hoped so Id like to take them off the list. Do I have to restart to factory settings option then just re-install the ones i want?
I tried searching this forum for uninstall and remove and didnt come up with any good quick answers. Can anyone help?
Cheers
Cheers
geposted Wed 22 Oct 08 @ 9:22 am
just go to the folder where you have them and delete.
geposted Wed 22 Oct 08 @ 10:55 am
Worked! Thanks!
geposted Wed 22 Oct 08 @ 5:25 pm
no probs mate...
geposted Wed 22 Oct 08 @ 8:10 pm
