Forum: Old versions
Topic: Skipping...but only when recording!!
Hi
I have been using VirtualDJ for some time now and have recorded quite a few mixes. During the mix the sound is fine, no skips whatsoever, but when I play back my recording and cut the tracks etc, low and behold i hear many small skips, probably at least 1 per track!
does anyone have any advice to offer me?
PC Specs
P4 2.8ghz
1024mb Corsair DDR400
200gb Seagate HDD 7,200 rpm
C Media On Board S/C
SB Live 6.1
Linksys Ethernet
Cheers,
Chris
geposted Tue 01 Feb 05 @ 6:34 pm
What version are you using...
2.05
Are you encoding your mix to mp3? If so it could be it but I don't really see why since you have a decent computer. If you have the mp3 encoding on, turn it off and then try recording one of your mixes and see if you get the same problem.
DJCHrisH You said been using for sometime .....how long?
