HELLO!!
JUST ONE QUESTION.
I have two laptops, the second one for backup, and sometimes a friend is playing with me at the club.
So, I have a DAC2 remote controller, is it possible to conect the dac2 (or another remote controler), with the two laptops, at the same time???
I mean, i want to control the first lap for some tracks, and switch to the other lap to play from there a few tracks. And all this i want to have the same remote controler (dac 2 in my case), to do this!!
IS IT POSSIBLE???
THNX
REGARDS.
JUST ONE QUESTION.
IS IT POSSIBLE???
THNX
REGARDS.
geposted Tue 01 Feb 05 @ 9:35 pm
You can get USB switches (The DAC is USB, right?) for less than $15. Not sure, but seems like it would work. Just do a google search.
I would assume that simply splitting the USB cable to run into both machines at once would be problematic.
geposted Tue 01 Feb 05 @ 9:42 pm
You can not connect a USB device to two computers at the same time. SCSI and Firewire allow you to dual attach but even that can be sketchy at best.
geposted Tue 01 Feb 05 @ 10:08 pm
wouldnt it be possible to network the laptops so vdj can play songs from both laptops on the laptop with the dac2 connected
geposted Wed 02 Feb 05 @ 6:07 pm
