I need an audio effect to let only the voice of a song (I need wet/dry option)
Is there anyone who knows how making an effect to let only the vocal part of a song or maybe where finding it?
geposted Sun 02 Nov 08 @ 4:43 am
This is impossibile to realize, because the only thing that you can do is to cut some frequencies. The voice has the same frequencies as some instruments, so you can't obtain the voice with an effect. Just 2 advices:
1. Use the Acapella!
2. Try to obtain just the voice with the noise reduction in Audacity (it's free and sometimes works).
See you!
See you!
geposted Sun 02 Nov 08 @ 11:25 am
You are wrong because to select only the voice you can do this:
the voice is usually mono so you need to cut the differencies between channel L and channel R and to adapt the phase of these two channels.
I don't want to use Acapella because I want to do it in real-time with VDJ.
I'm not talking about having perfectly only the voice because I know it's impossible, but at least reduce the sounds which are differents between channel L and channel R.
P.S: I have an effect called VOCAL+ created from Atomix Productions but it is without WET/DRY field
geposted Sun 02 Nov 08 @ 2:44 pm
