Forum: Old versions
Topic: Long Song Crashes?
Anyone else have the problem that songs over 10 min in legnth tend to crash VDJ?
First, songs over 10 min don't load the waveform on VDJ and second whenever I have a crash it is usually when I have an extended mix (10 min or over) on.
VDJ 2.06 Laptop 3 gig, 512k, 60 gig HD, xp pro sp1.
Thanks.
geposted Wed 02 Feb 05 @ 3:54 am
Change max load in the fame settings to always, add another 512 mb of ram.
Hi-
Thx for the tip. I changed max load to always, in my version it is under the general tab V2.06 (config>general tab>max load>always).
We will see in time if that helps.
Off to NYC this weekend & maybe try VDJ in real world environment...
Cheers
don't forget the 512mb of ram!
i have very few (if any) songs > 30mn, so I leave mine set to that..
jus seems like the "safe bet" option
Max load to "always" is not a safe option. If you load a big file (a mix for example) virtual dj will use
the swap file and this is not good.
