Forum: Old versions
Topic: cue liscence
Hey guys,
From what i understand Numark Cue comes with 2 liscences.
Can i buy more if i wish to put it on more than 2 computers? Or i need to buy the software all together again?
As well what happens if i install it on a 3rd computer? Does it lock out on one of the other 2? Or it just wont install? Any one know?
Thanks!
geposted Wed 05 Nov 08 @ 2:46 pm
Your license allows you to install Numark Cue on upto two computers providing they are for your own use.
If you need to install it on a 3rd computer, you will need to purchase another full license.
Please see the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
