Bien le bonjour à toutes et tous,
Avis à la population ...
Le nouveau controleur PCM.1 de chez SYNQ Beglec fonctionne nikel avec notre VDJ !
Il "suffit" :
- d'activer la fonction "MIDI" dans controleur externe
- de configurer le mappage des touches
J'ai commencé .. dès que j'ai le temps, je termine et propose en Download (avis à la team ;=)) )
INFO:
SYNQ's PCM-1 is a multifunctional 'designed in Belgium' PC-Media controller, designed for DJs switching from traditional mixing to hi-tech LAPTOP DJing!
This compact 19'/3U DJ-controller is fully USB MIDI compliant so it can be used with any DJ-software available.
Thanks to its well-arranged controls the PCM-1 is the ultimate tool for any computer DJ:
58 buttons
7 digital encoders with push-to-select knobs
9 digital knobs for tone + volume control
5 digital faders, including 1 user replaceable crossfader
2 jog wheels for scratching
2 'magic' shift-buttons double the functions of each control!
PCM-1 can be used on any modern laptop or PC (Windows® XP/Vista and Mac® OSX)
The built-in 6channel soundcard is ASIO-compatible and can be configured in different ways:
Mixed master output (internal mixer)
Decks A and B with separate outputs and fader start inputs (use with external mixer)
6.3mm Jack headphone output for PFL
PCM-1 comes packaged with a new professional DJ Software called 'Deckadance' (click here) .
NOT just some cheap, completely stripped LE-version but the full featured Deckadance 'House edition', including free upgrades, free online support and user forums and tons of free extra's such as royalty-free professional loops, samples, etc.
Deckadance has incredible nifty functions like '1-click' beat matching, automatic loops, 4 cue points per track, mix recorder, ...
Deckadance includes 8 samplers (recording/saving samples, volume, beat sync, pitching, effect, PFL, looping, ...)
Deckadance provides 2 Relooper editors each with effects and 3 fully editable patterns to slice, re-trigger, mute your tracks in perfect beat sync!
Deckadance can load any VST-compliant effect to ensure that your creative mixing skills become virtually unlimited!
Deckadance can run as a standalone program or as a VSTi plugin inside your favorite applications such as Ableton Live, Cubase, FL Studio, ... to ensure unlimited creativity!
Deckadance plays MP3, WAV and OGG
Pour les futurs acheteurs adressez moi un courrier, suis revendeur .. ;=) et en plus c'est en promo pour l'hiver 2008 ....
le prix ? 315 €
A bientot
Ooops
Jean-Yves
Il "suffit" :
INFO:
58 buttons
le prix ? 315 €
A bientot
Ooops
Jean-Yves
geposted Thu 06 Nov 08 @ 6:36 am
il a l'air pas mal ce contrôleur et sera accessible a un bon nombre de gens a 315€
geposted Thu 06 Nov 08 @ 7:32 am
Il manque un ou deux écrans, c'est dommage.
Merci pour l'info. ;)
geposted Thu 06 Nov 08 @ 8:49 am
il est complet pas besoin de table de mix c'est cool
geposted Thu 06 Nov 08 @ 8:59 am
Je pense que dans un espace aussi réduit, l'utilisation de la partie "table de mix" ne doit pas être aisée.
Et aussi, ne pas oublier que là c'est le logiciel qui s'occupe de la partie mixage. On est toujours plus réactif en utilisant une table de mix externe.
geposted Thu 06 Nov 08 @ 3:06 pm
SYNQ PCM.1
! Midi Mapper en téléchargement !
Description:
Synq Pcm.1 mapper
Supporte les doubles touches
A Lire : Readme.txt dans l'archive
Template et XML dans l'archive
@pnuche
Ooops
Jean-Yves
Download -> http://www.virtualdj.com/addons/5608/Synq_PCM_1_Midi_Mapper.html
Description:
Synq Pcm.1 mapper
@pnuche
Ooops
Jean-Yves
geposted Fri 14 Nov 08 @ 4:31 pm
bonjour a tous et merci a la personne qui a bien voulu mettre la version en download pour le controleur pcm 1........;
alors gros prob il m'est impossible de charger les paramettre dans mon programme
est ce que quelqu'un aurait la patience de me detailler la demarche a suivre svp car si je ne trouve pas je vais finir par balancer le controleur par la fenetre
par contre qui sait me dire pourquoi le programme deckadance fait tout le temps planter e pc?
c'est deconné il fournissent un truc ki fonctionne mal avec la commande
merci a vous
ced
merci a vous
ced
geposted Wed 07 Jan 09 @ 6:04 am
Salut ced,
Tu a pu télécharger le fichier en étant "No License User" .. humm .. étrange
La procédure est très simple
- Téléchargement du fichier
- Copie du fichier XML dans "Mes Documents/VirtualDJ"
- Lancer VirutalDJ
- Config
- Controleur Externe
- Clic sur "GENERAL MIDI" et Cocher "Activer"
- Clic sur "GENERAL MIDI" et Choisir "Config"
- Clic sur "Charger" et sélectionner le fichier XML
- Clic sur "Ouvrir"
- Clic sur "OK"
- Fermer VirtualDJ puis le relancer (pas nécessaire, mais on ne sait jamais)
Le manuel complet pour le PCM.1
Midi FAQ problem + Install PCM + Install Deckadance
Mise à jour Deckadance sur le site
N'oublie pas de completer ton comte sur le site avec ton numéro de série .. tu pourra télécharger le fichier.
En espérant avoir répondu à ta question.
A bientot
Ooops
- Lancer VirutalDJ
- Config
- Clic sur "Ouvrir"
- Clic sur "OK"
A bientot
Ooops
geposted Wed 07 Jan 09 @ 10:47 am
Bonjour Oops, un peu tard peut être mais vaut mieux tard que jamais......est ce que le même genre de logiciel existe mais pour le lecteur mixeur USB 900 de JB System ? Même principe que la Sync mais lecteur sd card et double port USB intégré ..
geposted Fri 19 Feb 10 @ 5:18 am
bonjour tu devrait ouvire un nouveau post pour ta demende
geposted Fri 19 Feb 10 @ 6:41 am
Bonjour Sentico, je suis nouveau et j'ignore en fait comment on doit procédé, tu peux m'expliquer un peu ?
geposted Sat 20 Feb 10 @ 3:12 am
bonjour a l'accueille du forum clic sur l'enveloppe au milieu
geposted Sat 20 Feb 10 @ 3:17 am
Salut à toutes et tous,
Pour l'USB900 aucune idée malheureusement.
Par contre depuis les dernières vers. de VDJ le PCM est automatiquement reconnu dans le mapping.
Et ca fonctionne à merveille ce petit engin .. N'oubliez pas que tout reste paramétrable à souhait.
Bon amusement
Ooops
Bon amusement
Ooops
geposted Sun 21 Feb 10 @ 11:40 am
