I just would like to say for the function "mix" , VDJ exactly does the same thing as my plugin (only for 2 songs in my plugin :-( ) but by using cue whereas i prefer using time ;-) Have a look in "Edit BPM", "automix" section
=> when you use automix+ fade=activated + fade_length=none , the played deck automatically changes AT THE END of the song
Of course automix is better than my plugin. I 'm always waiting for the correction of bug for no loading songs from the playlist in the previous case ;-)
The only improvment of my plugin is maybe the new types of mix (play or play synchro or play+pause or play+stop) which don't move the crossfader
geposted Fri 04 Feb 05 @ 11:53 am
iaew!!
geposted Sat 05 Mar 05 @ 3:51 am
