How to assign PFL to MIDI there is no opton in VDJ remote control config add window?
Cheers.
lee.
Cheers.
lee.
geposted Sat 15 Nov 08 @ 11:34 pm
All PFL settings are under system_volumes:
headphone_crossfader
headphone_mix
headphone_volume
headphone_mix
headphone_volume
geposted Sun 16 Nov 08 @ 6:52 am
No you, i need to know how to assign 'PFL" to a button so i can switch between 2 channels that only got the headphone cue and all that.
Farout you should understand my question?
geposted Sun 16 Nov 08 @ 11:57 pm
not fully... but:
If you are using the internal headphone mix option, than assign
two buttons to headphone_crossfade with values 0 & 4096.
As per manual, this will effectively have you hear only deck A, or deck B in the headphones.
I'm not sure this is possible to do with a single 'switch' button.
VDJ manual wrote :
headphone_crossfade
You can specify a value (between 0 and 4096)
ex:
- 0 (you hear only the left deck)
- 2048 (you hear both decs)
- 4096 (you hear only the right deck)
or specify the step and the direction of the fader:
ex:
- +128 (128 to the right)
- -512 (512 to the left)
ex:
ex:
geposted Mon 17 Nov 08 @ 2:17 am
No there is a way to assign this I will look into it, I asked Cstoll and he told me how but I dont remember.
geposted Mon 17 Nov 08 @ 2:52 am
Ok it is under Deck Controls, and it is Select, this selects the Active deck which is pfl. Set one shortcut to deck 1 and one to deck 2.
geposted Mon 17 Nov 08 @ 2:54 am
It would be just like clicking your mouse on the 1 or the 2 in the skin, is that what u are lookin for??
geposted Mon 17 Nov 08 @ 2:55 am
Yeah no sorry i was being abit aggressive,
My question was pretty vague in its description.
but NoW you know what iam talking about haha. Actually you did in the first place, i just did'nt take the time or use the brain power to investigate.
My bad!
I will try that out tonite, cheers. Thats pretty much all i need to work out and i have assigned all my controls to MIDI. All i need to work out except for "loopshift" but i cant seem to get the values small enough. Smaller than 1 for 1 beat anyway.
Cheers.
Lee.
My bad!
Cheers.
Lee.
geposted Tue 18 Nov 08 @ 1:55 am
Lee
I could swear that is what u need to do to switch between player 1 and 2 let me know.
geposted Tue 18 Nov 08 @ 3:05 am
Bang you are right on the money.
Thats exactly the button i wanted cheers discobrian24, cstoll came in to good use, lollys,
good stuff,
& cheers.
good stuff,
& cheers.
geposted Tue 18 Nov 08 @ 10:15 pm
No Problem man thats what we are here for, glad I could help
geposted Tue 18 Nov 08 @ 11:49 pm
hi all,
so sorry, not clear at all, where are the PFL buttons for deck A and B in virtual dj remote??
im trying virtual dj8 with external controller and i need to be wirelessly connected with my tablet but CANT pre listen decks because no pfl buttons on the APP
geposted Mon 30 May 16 @ 1:12 pm
