Hello - I am plannign to buy Numark DJ IO. I have Virutal DJ 5.2 Pro. Will this DJ IO work easily with it?
Any help is appreciated.
Thanks!
Thanks!
geposted Thu 20 Nov 08 @ 11:29 am
Yes, without any problems.
geposted Thu 20 Nov 08 @ 11:35 am
Any special setting, I need to make in Virtual DJ?
geposted Thu 20 Nov 08 @ 12:01 pm
No, you just select your sound card and the mode you wanna use and that's it. When you get it, feel free to ask and we will explain it step by step.
geposted Thu 20 Nov 08 @ 12:11 pm
ok, I just got Numark DJ IO. Just one small problem, hoefully someone can help.
I have the following.
2 - CDJ 400
1 - DJM 500 mixer (4 channels)
1 - Laptop with Virtual DJ
2 - CDJ's are going to Channel 1 & 2
Virtual DJ is going to Channel 3 & 4
Only problem is the Channel 4 on my mixer is for SUB mic and has no LINE, only PHONO and it sounds distorted.
Pls pls. someone tell me a workaround.
Thanks so much.
2 - CDJ 400
Thanks so much.
geposted Fri 21 Nov 08 @ 12:14 pm
You should use CDJ to control VDJ, should consider Pro version for full benefits. As for mixer, well that's restrictions it has, you can't make another input.
geposted Fri 21 Nov 08 @ 1:36 pm
ohhh ok!
So, how do I make the CDJ control Virtual DJ?
geposted Fri 21 Nov 08 @ 7:00 pm
hi guys! i´m having a problem i have the hardware hercules (dj control mp3) but i lost the cd with the software and im not able to control with the hercules the virtual dj...do you know where i can get a new software? or any kind of tips to put it working?? thank´s
geposted Sat 22 Nov 08 @ 9:36 am
Go to the Hercules web site...
geposted Sat 22 Nov 08 @ 10:08 am
Hi starvin marvin, u may redownload ur version at ur download centre as u already registered. Then u can also burn it into a cd for later use etc. Hope this what u looking for;)
geposted Sat 22 Nov 08 @ 10:12 am
ozab75 wrote :
ohhh ok!
In VDJ go to Config>Remote Control and select activate on the picture of CDJ 400.
geposted Sat 22 Nov 08 @ 10:16 pm
2 - CDJ 400
Thanks so much.
2 - CDJ 400
Thanks so much.
You can get something like this to convert the phono input on channel 4 to another line.
http://www.kabusa.com/preconlp.htm
Alternatively, looks like someones made a plugin too:
https://virtualdj.com/addons/1235/Inverse_RIAA.html
geposted Sun 23 Nov 08 @ 10:31 am
