Howdy all,
I am working on my senior thesis and it has to do with a new type of controller for DJing! I chose to use virtual dj because of the custom plug ins and various skins, but because I only have the demo version this site won't let me get to them. I know the obvious thing to do is go out and spend the $200 and get a serial but I don't have that kind of money to spend, so I figured I would come to you guys and ask if you would be willing to send me a plugin now and a gain for this project I would really appriciate it! You will be get credit for helping and I will send you a copy of the final thesis if you want.
I just really need some help!
Thanks,
Alex
Thanks,
Alex
geposted Thu 20 Nov 08 @ 8:42 pm
Sorry, you must purchase VirtualDJ to gain access to downloading plugins and other add-ons: https://virtualdj.com/buy/
Please DO NOT ask our registered licensed users to send you plugins. This will not happen.
If you have programming skills, you can create your own plugins using the SDK: https://virtualdj.com/wiki/Plugin_Guide.html
geposted Thu 20 Nov 08 @ 9:11 pm
If you're creating a controller, it will need to be MIDI to work, so you won't need access to any plugins anyway :)
geposted Fri 21 Nov 08 @ 5:58 am
Yup, all you need is to know the midi protocol, and you can program it
for this software.
http://www.gweep.net/~prefect/eng/reference/protocol/midispec.html
Unless you'd want a full native support, but than you'd need to get in
contact with the company anyway...
for this software.
geposted Fri 21 Nov 08 @ 10:35 am
