Is there a solution to use 3 decks with TC vinyls in VDJ (e.g. with 2 Maya 44 cards)?
Currently I can use my 3rd Deck only to mix in real vinyls.
geposted Mon 07 Feb 05 @ 8:44 pm
In theory i think yes, you just need 3 inputs and be careful with ouputs. Interesting to know that. Reply if you succeed
geposted Mon 07 Feb 05 @ 8:53 pm
in the setup of vdj i only have the opportunity to configure a left and a right channel and not a thrid channel? will i have to use multiple instances? if yes, how do I configure them to each save their settings
geposted Mon 07 Feb 05 @ 10:26 pm
I use 2 PCs with 1 monitor , 1 mouse and 1 keyboard ....
geposted Mon 07 Feb 05 @ 11:29 pm
well launch a new VDJ and you wil have your 3 even 4 decks ;-)
geposted Mon 07 Feb 05 @ 11:49 pm
yes ok but how do i have the settings for each instance separately? und how can i synchronize the decks?
geposted Tue 08 Feb 05 @ 2:29 am
The "beatlock" button enables you to synchronyse your 2 vdj using a local loop 127.0.0.1 (network section). I don't know more to help you
geposted Tue 08 Feb 05 @ 2:34 am
