MC-7000
Setup
Firmware & Drivers
Firmware : Make sure your device is at the latest firmware. Check at https://www.denondj.com/downloads for any available update.
Drivers : (Windows only) Download and install the latest Windows drivers from https://www.denondj.com/downloads
No driver is necessary to be installed on Mac OSX computers.
VirtualDJ Setup
Once VirtualDJ is opened, a Connect Window will appear. Login with your virtualdj.com account’s credentials.
A Pro Infinity or a Pro Subscription License is required to use the Denon DJ MC-7000. Without any of the above Licenses, the controller will operate for 10 minutes each time you restart VirtualDJ.
Click on the MC 7000 button in order VirtualDJ to apply the pre-defined audio configuration (speakers need to be connected to the rear side of the unit in this case)
Click to OK
MIDI Operation
The unit should be visible in the MAPPING tab of VirtualDJ Settings and the “factory default” available/selected from the Mappings drop-down list.
Find more details at http://www.virtualdj.com/wiki/VDJ8script.html
AUDIO Setup
The unit has a pre-defined Audio setup and a special button in the AUDIO tab of Config to provide that.
See also Inputs & Recording.
For further software settings please refer to the User Guide of VirtualDJ.
https://www.virtualdj.com/manuals/virtualdj/index.html
