Kontrol S8
Deck Controls
S SHIFT.Hold this button down to access additional functionality for several buttons/knobs as described in this manual.
- 	PLAY: Play/Pauses the track.
-   Cue : When the Deck is paused, you can set a temporary  Cue  Point by moving the Platter to place the Audio Pointer at the desired location and then pressing the  Cue  Button. During playback, you can press the  Cue  Button to return the track to this  Cue  Point. (If you did not set a  Cue  Point, then it will return to the beginning of the track.). If the Deck is paused, you can press and hold the  Cue  Button to play the track from the Temporary  Cue  Point. Releasing the  Cue  Button will return the track to the temporary  Cue  Point and pause it. To continue playback without returning to the Temporary  Cue  Point, press and hold the  Cue  Button, then press and hold the Play Button, and then release both buttons.
-  SYNC: Use this button to match Tempo and Beat-Phase of the deck with the values of the opposite deck (or  Master  Deck if more than 2 decks are used). The  Master  Deck selection is made automatically by VirtualDJ, mostly depending on the Deck that is playing out in  Master .
 Hold SHIFT and then use this button to reset Deck's Tempo to its original value
-  NEEDLE SEARCH: When Track is paused, touch and slide to left/right to fine-position Track. When Track is playing, touch and slide to left/right to bend (temporary increase/decrease Tempo).
 Hold SHIFT and then slide to left/right to Seek (Search) through the Track
 -  DECK: Swap Left/Right Decks. Use the Left DECK button to toggle between Decks 1 (blue led) and 3 (white led). Use the right DECK button to toggle between Decks 2 (blue led) and 4 (white led)
-  FLUX: Use this button to enable/disable Slip mode. When Slip mode is enabled, several functions such as Hotcues,  Loops , Scratching etc, will act temporary (track will resume playback from the position it would have been if this function was never executed)
-   Loop : Turn left/right to half/double the size of the  Loop . Push the encoder to turn on/off a  Loop . Hold SHIFT down to move the  Loop  backward/forward by 1 beat.
-  EDIT:  Not pre-defined to any operation
-  CAPTURE: Use this button to save the current  Loop . when saved, use this button to enable/prepare the saved  Loop . Hold SHIFT down and use this button to delete the saved  Loop .
