PartyMix MKII
Numark - PartyMix MKII
Setup
STEP 1 : CONNECTIONS
STEP 2 : DRIVERS & FIRMWARE
Drivers : No driver is required to be installed. The Party Mix is a USB Class compliant device and your Operating system will automatically install the necessary drivers once the unit is connected to your computer via a USB port.
For Windows, an optional ASIO driver can be installed from https://virtualdj.com/documents/Drivers/Install%20Numark%20Party%20Mix%20MKII%201.0.0.exe
If the Windows Driver is not properly installed, follow instructions from https://support.numark.com/en/support/solutions/articles/69000858213-numark-party-mix-ii-and-party-mix-live-driver-will-not-install
STEP 3 : VirtualDJ Setup
Download and install VirtualDJ from https://virtualdj.com/download/ (in case you have not done already)
Once VirtualDJ is launched, a Connect window will appear to enter your virtualdj.com account credentials.
A Pro Infinity, a Plus Controller or a Pro Subscription License is required to fully use the Numark Party Mix MKII. Without any of the above Licenses, the controller will operate for 10 minutes each time you restart VirtualDJ.
https://virtualdj.com/buy/
A detection window will appear when the unit is first connected with VirtualDJ, verifying proper connection.
Click on the "Party Mix MKII" if your speakers are connected to the Main Output at the left side of the Party Mix MKII.
You can still make changes in the Audio setup from VirtualDJ Settings->AUDIO tab.
Press OK.
The device is now ready to operate.
Controls
