DDJ-WeGO2
Pioneer DJ - DDJ-WeGO2 - Layout
Mixer
  1. CROSSFADER: Blends audio (& video if LINK is enabled from the VIDEO panel of VirtualDJ 8 GUI) between the left and the right assigned VirtualDJ decks.
  2. VOLUME: Channel Volume Faders. Faders alter the sound of the left and right software deck.
  3. Cue /PFL: Press this button to send this channel's pre-fader signal to the Cue Channel for monitoring. When engaged, the button will be lit.
    Hold SHIFT down and then use these buttons to select a different color for the Jog illumination (selection is per deck and will not affect the jog color of the VirtualDJ WeGO2 skin – if used)
  4. EQ LOW: Adjusts the low (bass) frequencies of the left or right assigned deck.
    Hold SHIFT down and then use this knob to adjust the intensity of the blue color of the DDJ-WeGO2 jogwheel.
  5. EQ MID: Adjusts the middle (mid) frequencies of the left or right assigned deck.
  6. EQ HI: Adjusts the high (treble) frequencies of the left or right assigned deck.
    Hold SHIFT down and then use this knob to adjust the intensity of the red color of the DDJ-WeGO2 jogwheel.
  7. LOAD: Load the selected track from BROWSER to the left or right assigned VirtualDJ deck.
  8. BROWSE Knob/push:
    Use this knob to scroll through files. Push the knob to toggle between the normal Decks view and the Browser Zoom panel of the VirtualDJ WeGO2 GUI.
    Hold SHIFT down and then use this knob to scroll through the folders. While SHIFT is pressed, push the knob to open/close sub-folders.
Decks
